Contact US
NX12 pattern curve
NX12 pattern curve
NX12 pattern curve
So I have some graduated markings that span a distance of 110mm and there is a dash every 5mm I sketch the first line and get "sketch fully constrained" but as soon as I pattern that linearly I get "sketch needs 440 constraints" any idea on why its not bringing my constraints along with the pattern..?
Blase
RE: NX12 pattern curve
this is odd. Unfortunately hard to help without the source file. Anyway, the constraints should be embedded in the pattern feature. Beware of reference geometry (like line converted to axis) which requires to have end points constraints to be considered as "fully constraint".
Do you have the "Create inferred constraints" on or off ?
If this option is OFF, one will need to create constraints for all the new geometry.
Notice that :
with the Create inf... ON, the options available for pattern curve inside the sketcher is limited to linear/circular/general
with the Create inf... OFF, the options available for pattern curve inside the sketcher expands to linear/circular/polygon/Spiral/along/general/reference
There are no algorithms in NX12 to keep these "extra patterns" as associative/parametric in the sketcher.
(There are if using the Pattern Geometry outside the Sketcher.)
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.smile
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
