  • Congratulations IRstuff on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Struggling with structural grid and placement of stability walls 1
rhmj
Student
Apr 10, 2021
This is the ground floor (3 floors total) of my build. Floor 1 overhangs on the two south facing facades, hence why the columns are "outside" of the ground floor walls.
I think the structural grid is okay - but I would like to ask whether the dotted lines of the grids actually represent where beams will go or are they just to work out where to put the columns? (I'm a first year Architecture student so please be kind - I'm not up to speed with the structural stuff!)
If they are beams, then I'm not sure if D8 would work. The brown smudgy line is the balcony of the first floor and so I couldn't have the beam coming out of that to the back wall.
My main question is stability. I've put orange rectangles around where I thought I could put the stability walls, but I don't think they follow the three rules I've been told:
1) Must have stability elements in each orthogonal direction
2) Must be perpendicular distance between two parallel stability elements
3) Centre of stiffness of the stability elements should be somewhere near the middle of the building
Does point 1 mean they HAVE to be at 90deg to each other? Because I have no walls that satisfy that rule. Or since they are roughly facing each direction, is this okay?
Again I don't have walls that are of exact distance from each other to satisfy point 2. Rectangle X and Y for example are closer to each other on the left side but the distance between them is larger on the right side.
Does point 3 mean I need other stability walls in the centre?
Thank you so much for any help
Grid lines are defined just as an aid or a reference point for ease in placement of structural elements during construction. It's not necessary to define grid line at every beam. Similarly, it isn't mandatory that every grid line must have a beam aligned on center.
My main question is stability...I don't think they follow the three rules I've been told:
The intent of the rule no.3 is to keep the relative distance between center of mass and center of rigidity as small as possible. Large difference between the two points could result in significant torsional deformation of the building.
In fact, in one way or other, the intent of all three requirements seems to provide the most optimal mechanism to resist, or prevent the torsional mode of the building.
For example, the requirement for a pair of walls in each orthogonal direction serves dual purpose of resisting lateral force along the plane of wall plus the torsional moment due to lateral force in the perpendicular or transverse direction. The requirement for perpendicular distance between the walls is to achieve the maximum capacity to resists the twisting of the building.
Some thoughts related to your building:
Buildings with large projections and plan aspect ratios could create unwanted complexities in regards to lateral load resisting system. Therefore, it is very important for a designer to examine the best possible location to place the structural wall.
Firstly, it is difficult to provide a direct load path to transfer the lateral force from stories to the ground in a non-orthogonal building without creating points of stress concentration. Secondly, lack of symmetry in plan, in most cases, give rise to torsional mode of vibration in the earlier modes. Non circular columns are not good in resisting moment about axes other than their orthogonal axes. Therefore, the best structural system for complex shape buildings are those which would push the torsional mode of vibration to the later modes.
In addition, floor slabs in building with large aspect ratio with walls at end of the buildings only, may result in flexible diaphragm condition instead of desirable rigid diaphragm action. Providing walls between the ends of a building at certain intervals could prevent flexible diaphragm behavior. The thing with flexible diaphragm is that its in plane stiffness is almost negligible compared to the LFRS, so the diaphragm does not facilitate any interaction between frames. In addition, the distribution of lateral force to resisting elements is approximately based on the tributary area of the slab, unlike rigid diaphragm, which distribute the force in proportion to the relative stiffness of resisting elements. Thus, flexible diaphragm could result in overloading the element with less capacity.
Thank you so much for such a detailed response, it's definitely helped me understand it better!
