Cutting force comparison method
Hi, I am conducting 2D orthogonal cutting of certain material and I want to compare the results of cutting force from different cutting speed.
So for example, I have using 50mm/s,100mm/s and 150mm/s, my question is, should I take cutting distance or the step time constant?
If I take the same step time (0.01s) for all 3 simulation, eventually they will have different cutting distance.
If I take the same cutting distance (1mm) for all 3 simulation, then they will have different step time at first.
I am currently using approach 2, but I am not sure if it is correct. Or both of these approach do not matter as long as the cutting force is stable at certain cutting distance?
Thank you very much.
RE: Cutting force comparison method
Constant cutting distance seems like the way to go here because with this approach you can compare various cutting speeds realizing the same task (machining the same workpiece).
Noted, thank you very much FEA way!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
The Great Project Profitability Debate
A/E firms have a great opportunity to lead the world into the future, but the industry’s greatest asset—real-time data—is sitting wasted in clunky, archaic ERP platforms. Learn how real-time, fully interactive dashboards in a modern ERP allow you to unlock data that will shape the future of the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
