Contact US
Cable Carousel
Cable Carousel
Cable Carousel
Hello Everyone,
I'm trying to figure out the acting force on the the wall/fence of a cable carousel as in following image:
I tried to look for a design standard but so far I couldn't find one. So, here is my assumption:
n : vertical number of cable layers
nh : number of cable turns on each layer
M : total cable mass on each turn
Mnh : Mass of cable on each horizontal layer, i.e; M1, M2, M3, etc...
g : gravity
I know that there will be a cable transition between each layer. So, i'm assuming that 'nh' for all layers will be the same (the image above is simplified).
F1 = 0 N
F2 = 1 x (M1+M2+M3+M4+M6+M6)/2 x g
F3 = 2 x (M1+M2+M3+M4+M6+M6)/2 x g
F4 = 3 x (M1+M2+M3+M4+M6+M6)/2 x g
F5 = 4 x (M1+M2+M3+M4+M6+M6)/2 x g
F6 = 5 x (M1+M2+M3+M4+M6+M6)/2 x g
Fn = (n-1) x M/2 x g
Note:
1. I divided total mass, M by 2 as I'm assuming external and internal wall will share the force together.
2. There will be a safety factor to be applied too base on standard offshore structures/machineries.
Is there any other things I have to take into consideration?
R.Efendy
RE: Cable Carousel
How have you made the downward force of gravity act horizontally?
I see no basis at all for assuming that the ID and OD would equally share load.
Radial forces will be produced by tension due to winding and the cable's desire to straighten itself.
RE: Cable Carousel
are you sure that the cable is in touch with internal/external wall ?? first (and similar layers) of your sketch is/are impossible to me
RE: Cable Carousel
The horizontal force comes from the wire nesting between the pair below it. The force is substantial on the cheek plates of winch drums.
RE: Cable Carousel
Force on cheek plates is due to cable tension. In a cable carousel the cable is loaded at low tension. The tensile strength/stiffness of the cable prevents the hoop from expanding after being laid in the carousel. The carousel is mainly bracing to keep the pile stable.
If the carousel tilts, in inside core will carry almost all of the side loads.
Also, you cannot have a closest packing configuration because each layer will alternately be spiraling inward and outward.
RE: Cable Carousel
TugboatEng, I'm not so worry for a winch drum because I've designed one. Also I can refer to DNV Standard for Lifting Appliances.
What Compositepro said about the winch cheek plate (flange) is correct. Also the loading taken by the center core does make sense. No wonder I see all the outer core of the carousel are designed in such a simple way.
R.Efendy
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
