Inventor Crashing While Printing Large Assembly Drawings to HP OfficeJet Pro 7740
tz101
I have a recent issue printing large assembly drawings (20-30 sheets) to an HP OfficeJet Pro 7740 printer. Has anyone else experienced a similar issue, and is there a known fix?
Thanks.
Print to PDF.
Print the PDF to the HP.
Does that help?
It is unlikely that you have provided enough information in your posts to offer any more helpful advice than that, unless they just happen to have solved the exact same problem recently.
Please remember: we're not all rednecks!
I have done the print from PDF thing and it is a workaround, but shouldn't HP and/or Autodesk have a fix?
