ordinate arrow
grunt58
How do I add an ordinate arrow to show which direction it is coming from? Chain adds chained arrows to all ordinate dims. I thought there was a way to just show a short arrow at the ordinate dim.
Depends on which dimensioning standard you're using. I have seen that feature on ordinate dimensioning but not sure where. Check ISO, ANSI, etc.
I fudged it. Separated the top and bottom of the zero of the view. Also added some sketch lines to separate the areas.
