Leading-order equation
Yeah, but the left side of the equation stayed at d^2, should it not become the first derivative after the integration?
Take the integral in ∂z of both sides, then multiply both integrands by ∂T/∂z , so that the right integral is in ∂T, and you can calculate it as above, and on the left you have (∂T/∂z)2 I cannot explain the factor 2 in the result, though.
prex
[URL unfurl="true"]http://www.xcalcs.com[/url] : Online engineering calculations
[URL unfurl="true"]https://www.megamag.it[/url] : Magnetic brakes and launchers for fun rides
[URL unfurl="true"]https://www.levitans.com[/url] : Air bearing pads
