Distribution of base shear forces in ETABS
Yousef ZAA
I have a question that may sound trivial! If I modelled a wall in ETABS as a shell thin and applied on shear forces at different levels, and I defined the restraints at the base on the two edges as pin-pin, shouldn't the two reactions at the base be equal?
I see a difference in reactions, of course the total sum is correct, but why wouldn't I get equal reaction? See attached.
 https://files.engineering.com/getfile.aspx?folder=ad9a97ef-09e7-4c87-9a6a-787696af9c0e&file=2.png
