Lightly reinforced concrete walls (ICF and other)
Hello all, first post. Great forum!
Just working out for a bit of a retrofit/ design change in an ICF.
I'm proposing installing a steel beam to bear on the concrete core
- it's minimally reinforced but can treat it as an unreinforced stocky column & the axial load at 0.36fck is OK.
Simply supported beam assumed. (btw is it OK to assume no moment transfer if installed on a padstone?)
Just wondering if the reinforcement yielding would cause an issue or what other way I would approach this? - as per .. trying to minimize abortive works!
Thanks!
Thanks!
RE: Lightly reinforced concrete walls (ICF and other)
