Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Harbringer said:Use importance category IV (Ie=1.5). If the client has a bigger budget than a hospital and wants a structure that doesn't get any "credit" for it's inherent ductility set R=1.0
If a building is deigned with R=1 (elastic) under maximum earthquake, does that guarantee building operation after a seismic event? Do ASCE/IBC allow for this?
bones206 said:Is there a specific provision in the ASCE ELF provisions that allows you to use R=1 for any system? Or is it more of an engineering judgement thing?
IMO, to make sure for fully operational, make an assesement study for the structure , MEP, Architectural elements and fix the displacement requirements.
dauwerda said:I believe this is the closest you are going to get to a provision that "allows" this.
Do you understand what setting R=1 does? It will increase your Cs (seismic coefficient). Tell me, what is reckless for designing for a seismic load that is greater than code minimum?bones206 said:This is just my opinion, but I think it's a bit reckless to set R = 1.0
bones206 said:For example, if you set R=1.0, what's your overstrength factor and where would you apply it?
BAGW said:If a building is deigned with R=1 (elastic) under maximum earthquake, does that guarantee building operation after a seismic event?
BAGW said:Do ASCE/IBC allow for this?
