This is a technical question regarding the 318-14 Building Code Section 17.4.5: The equations for bond strength in tension appear to have a "glitch". The tensile capacity should be a function of the effective length of the bond. However, the critical edge distance is also a function of the bond length; this critical edge distance ends up in the denominator of a ratio, causing the bond length to "cancel out" of the equation. So, you see, I am up a creek without a paddle.
FYI: I have tried to contact ACI regarding this; however, they require membership for this inquiry.
Please respond ASAP as I have a client waiting! Thank you.
Richard L. Flower, P. E., LEED Green Associate
Senior Structural Engineer
Complere Engineering Group, Inc.
