ASCE MWFRS Directional Procedure Mean Roof Height
Hi all,
I am working on a structure that has tow low roofs surrounding a middle gynasium which is a separate higher roof. The average height of low roof is 14' and that of higher roof is 21'.
While caculating the ASCE MWFRS wind load using directional method, what do you guys use as 'Mean Roof Height' for the purpose of determining external pressure coefficient 'Cp' and velocity pressure'qh' for leeward walls?
Thanks.
Thanks.
RE: ASCE MWFRS Directional Procedure Mean Roof Height
