In ASCE 7-22 (and 7-16), equation 15.4-6 is used to find the fundamental period of a non-building structure, and by its inverse, the natural frequency. It's a simple enough calc for the 10'x10'x5' braced frame structure I'm designing for a piece of equipment that requires a maximum 20Hz limit. If I wasn't required to provide calculations for this, I could simply do an eyeball test and say it meets that limit.
I'm sure I'm overthinking it, but it's a bug in my brain now and I want to sort it out. I'm having trouble finding direction on the variable 'g' (I know, it's gravity). Section 11.3 doesn't provide units for g and if my deflection is measured in inches, it somehow makes sense to use g=386.4 in/s2 (=32.2ft/s2 * 12in/ft), but the inverse of equation 15.4-6 would be 32Hz which cannot be right. Using g=32 ft/s2, gets 9.2Hz which is more reasonable but having the conflicting units doesn't sit well with me. Does anyone know where ASCE gives direction on the units to be used for g throughout the code?
Further, this equation doesn't take into account the site specific conditions. It would make the most sense to me if SDS was used in this equation rather than g. Is there any rationale to this or am I overlooking something?
I appreciate the input. Thanks.
