Contact US
Effect of Slender section in the design
I noted that Sap is not taken the effect of slender section in design , i did experimental trial by increasing the width of flange and reducing the thickness the local buckling became non-compact then i did it same more time but still the section is non-compact and not jumping to slender ,however as per ASIC if b/2tf is more than (E/fy)^0.5 the section should be slender in local buckling.
Please if anyone faced this issue before advice me otherwise i have to design each section manually
Thank you
RE: Effect of Slender section in the design
What version of the program are you using?
I've done these tests multiple times in the past. I tend to prefer to use fully braced sections and just modify the Fy until I can make it slender. That way, we all know the dimensions that you're dealing with.
Also, I don't just look at the section classification. But, I also look at the capacity of the section to see how it's changing with slenderness and such. I seem to recall an issue I ran into awhile back where I thought the program should report slender, but it wasn't. However, the capacities were reduced correctly as they should have been per my slender member calcs. I remember concluding that it was either a reporting issue or a difference in what type of slenderness we were talking about.
I am using the latest version of sap.
I think sap is not designed the sections in case of slender ,only if the section is compact or non-compact he designed otherwise he will give you unsafe section or overstressed ,I don’t know if this leak in the software or what because slender sections in the built-up sections can easily used specially in the long span.
Thank you
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
