Selecting Elements in ANSYS APDL
I am using ANSYS APDL for the analysis. I want to select some elements from the model after doing my analysis but due to deformation of the model the elements location change and are not selected by suitable commands.
If somebody could help me in getting the pre-analysis geometry that will be highly appreciated.
Showkat Ahmad Kumar
Showkat Ahmad Kumar
RE: Selecting Elements in ANSYS APDL
Rick Fischer
Principal Engineer
Argonne National Laboratory
Yes I am using UPGEOM Command (initial imperfection). Since the selection of items is needed in the postprocessing so to select item in preprocessing will not be a good option that is why I was searching if there is some command which will give me the shape of geometry before UPGEOM.
Rick Fischer
Principal Engineer
Thanks in advance
