Jan 7, 2021 #1 Thanh Tran Industrial Joined Jan 7, 2021 Messages 33 Location US Hi, What’s cutting condition to cut 1/4” thick mild steel on Mitsubishi LVP 3015 40 CFX? Thanks.
Jan 11, 2021 #2 laserkatana Mechanical Joined Nov 25, 2015 Messages 32 Location US Try this and let me know if you need further help. https://files.engineering.com/getfile.aspx?folder=a84fd926-ad73-416c-8538-2f48bff7add0&file=MS_O2_250.pdf Upvote 0 Downvote
Jan 12, 2021 Thread starter #3 Thanh Tran Industrial Joined Jan 7, 2021 Messages 33 Location US Thanks laserkatana. Can I cut this material using nitrogen? Upvote 0 Downvote
Feb 11, 2021 #4 laserkatana Mechanical Joined Nov 25, 2015 Messages 32 Location US You can try using a B01 nozzle and if there is a supplied cut condition for .250" MS with N2, if not use a SS Conditions of equivalent thickness. Upvote 0 Downvote
Mar 23, 2021 #5 Rex Hang Industrial Joined Mar 4, 2021 Messages 26 Location IN There are many ways to cut mild steel plate, some of which are suited for automation some are not. Some are suited for thinner plate, some for thicker. Some are fast, some are slow. Some are low-cost, some expensive. Upvote 0 Downvote
