Non-linear material in Nastran
Ale22pic
Aerospace
IT
Hi guys!
First of all, I'm new to this forum and this is my first thread, so if there are some mistakes in the way that I posted it tell me. Anyway, I'm working on finite element simulation with Patran and Nastran on a particular composite material, actually, we can say it's a sandwich. I'm trying to simulate the different behavior of these sandwich faces because they act differently in compression and tension. So I thought to write a field in which I set the strain and stress, but I can only use this field for isotropic/nonlinear elastic material but the material used for the faces is a composite made of unidirectional fibers layers at different angles. If I wasn't clear tell me and I'll give you more details in a way to resolve this problem together.
Thanks for your cooperation!
You use PCOMP/MAT8 cards for composite layer definition.
I dont recall, but there may be a way to define a nonlinear MAT8 card with different tension and compression moduli. Read the manual.
Hi, SWComposites! Thanks for your answer. Honestly, I took a look at the manual but I didn't find anything useful, but probably I wasn't good in searching (I read Nastran 2018 Quick Reference Guide). Would you like to give me more details if you know more about this kind of problem?
