Friction factor - Foundation on Roof structure with insulation inbetween
Khan003
I want to know how to calculate the friction factor if i have a foundation slab on roof structure with insulation between Roof and Foundation slab? can anyone cite any sources or tests? I would really appreciate any help or guidence. Thank you in advance
If its on a root structure its not a foundation slab then? This sounds very weird.
You will have to provide a sketch.
Generally coefficient of friction depends on the properties. You need to define what the "roof structre" is.
A detailed cross section is needed.
So i made a rough sketch of how it looks like:
by roof i mean reinforced concrete slab (black). The building has a large flat slab (black). On top of this reinforced concrete slab their is a small slab/foundation (blue) on which a frame is supported and between this so called foundation and slab their is a insulation material (red).
I wouldn't rely on friction in this case. If the added foundation is there to stay, it needs positive tie downs.
ignore the insulation and your friction factor is concrete to concrete.
thread167-11539
