Changing section view for every new drawing file
ngkw1
15
Hi. I am trying to change my section view setting from the default standard with connector to standard without connector for all my new drawings. I have changed the drawing Document Properties > Section > Standard without connector but everytime I start a new drawing and make a section view, it kept creating section view of standard with connector which I do not want. I have to change the setting again everytime. I thought when you changed in document properties, all new drawings will follow the new setting. Please advise. Thank you.
I think you are talking about Detail Views, not Section Views. Is that correct?
