Anchor bolts
Anchor bolts
Dear All , I need your help to choose the right material for flare riser anchor bolts ,the available materials are (S355J2 , Grade 1045 , C45R-01).The designer suggested ASTM A 307 Gr.C but its not available right now. Note that the flare riser Hight 55m and the the design wind speed 45 M/S .
RE: Anchor bolts
Rise height and wind speed tell us nothing. If all you care about is structural load, it's also impossible to choose a material without knowing bolt sizes, locations, quantities, etc etc.
Your designer is the only one who can help you.
RE: Anchor bolts
https://www.dywidag-systems.com/fileadmin/download...
We used them for the steel stacks using hydraulic pretensioning. You need to leave sufficient gap for the extension of the bolt and the pretensioning devise. Contact them for these for the selection of pretensioning device and perhaps for the anchor bolt material, ask all the questions in your mind for the operation before hand.
Hope it helps.
RE: Anchor bolts
A307 Grade A
A354 Gr BC
A354 Gr BD
A449
Table 2.1b Anchor Rods
A36 (F1554 Gr 36)
A193 Gr B7
A320 Gr L7
F1554 Gr 55, Gr 105
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
