Load values are rounded down
How can I prevent FEMAP from rounding down load values? Where is even this option available?
Load values applied at the node are correct when I check by clicking on the load and edit. please help
RE: Load values are rounded down
I don't know if I understand the issue correct. Isn't it just an issue with how many digits Femap shows you in a figure?
If so, try "View Options" - "Labels......" - "Load vectors", and press "Digits" for options.
Thomas
You can also check if the actual load value is being rounded by previewing the analysis set and finding the bulk data load entry to the node(s) of concern.
