choice of blanketing
BZLAM21
Petroleum
Aug 12, 2020
61
Dear All,
we are desinging a JETA1 storage tank(fixed roof), for that we was asked to do blanketing.
shoul use Nitrogen for blanketing or Fuel gas?
Your help on this is appreciated.
Thanks.
0707 could you please explain the basis of your choice?
there is not a floating screen inside
Well first define why you're doing the blanketing.
Fuel quality or explosion risk?
For me there isn't that much in it, but your fixed roof won't like very much in the way of extra pressure ( inches water column). Your supply needs to be pretty good otherwise you can collapse the tank when you draw the Jet A1 out. what is more available?
0707 - that link doesn't work for me. why not post the image into the post direct using the Image button above.
Typical refinery fuel gas is high dewpoint fuel gas, which will contain some high mol wt components that will gradually dissolve in the jet fuel and mess up your jet fuel IBP. So you would be better off with N2. And you have the added benefit of a smaller Zone 2 area around the vents at tank top with N2 blanketing (I would guess, check with hazardous area classification engineer)
I would echo the concern with fuel gas negatively impacting product quality. Fuel gas is generally high in H2S and other less than desirable components.
While it's great because it's free, it can be inconsistent in availability and pressure.
Most JetA tanks are not blanketed. Why would you do such a thing?
