Nastran solver creates too much big files
suslu13
17
Hi all
I have a job to run. There are a lot of loadcases therefore the results opt file is 80gb.
Eventhough i wrote scr=yes Nastran needs 240 gb space. Nastran solves the job 2 hours in HPC.
Is there any way to reduce the space for solving the issue?
What are the recommendations for solving such as huge files?
You can reduce the number of output vectors (for example output only stress) or reduce the number of nodes/elements to output results.
can you post your f04 file of the completed run?? that can provide insights into the tuneups required.
@nlgyro i cant not provide f04, it is in my company notebooks. Could you tell me where i will look in f04?
