Searching FOr equivalent Steel Grades
RE: Searching FOr equivalent Steel Grades
It's a nominal grade 300 steel. That standard is particularly for flats and hot rolled sections (I-sections, PFC's and angles). Just normal carbon steel with varying CVN values depending on what subgrade you are specifying.
The New Zealand and Australian steel codes are written around Australian, New Zealand, British and Japanese sourced steels. There is no direct equivalence for US material substitutions.
What equivalence are you looking for, using American sections in New Zealand/Australia? Or using Australian sections in America?
A Grade 50 might do the job as I don't think there's an upper limit on yield, nor any extraordinary properties.
I found a copy free on internet
300 MPa ~= 44ksi for yield strength.
The most common material specs for the types of sections described by Agent666 are A36 (Fy = 36 ksi =~ 250MPa) for Channels, Angles, and Plates and A992 (Fy = 50 ksi =~ 345 MPa) for Wide Flanges/I-sections.
You can get channels/angles/plates in higher grade (50 ksi) steel, but depending on where you are sourcing there may be a cost increase/availability issue. Talk to some local fabricators for more information.
For S0 seismic subgrade there is, and this would be required for any seismic systems. But OP needs to explain what equivalence they are after here. There is a process for qualifying foreign steels to use in NZ for example, it is expensive and time consuming and mainly directed towards protecting against lower quality Chinese sourced steel. Can offer further advice once OP chips in with further info if that was their intent.
Off topic, I'm idly wondering whether Aus steel is typically S0 but just not guaranteed like in NZ.
Steveh49, unsure on that. There's certainly some small differences required/allowed in the metallurgy if you review the appropriate tables in 3678.1.
But the main difference as I understand it, is in proving the higher elongation requirements, higher CVN values and upper limits/variation in appendix F. Whether they need to alter the metallurgy for this or if its just a matter of doing the required testing and building up a historic record I'm not sure of? Honestly don't even know if there is a price premium for the S0 grade vs other none/L0/L15 sub grades.
Most of our hot rolled stock in NZ comes from Australia or selected qualified (ACRS?) Mills in Asia as I understand it. I think we only produce some plate, angles and hollow sections here in NZ but could be wrong on this.
A lot of American mills will make their A36 meet CSA G40.20 44W, which is 300MPa. You can ask the mills for 44W and see what comes up.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
