HydroCAD Tc Line Method for Dry Swales
I was wondering what method I should use when Tc line is going to a dry swale? There is an underdrain pipe, but I don't think it is proper to select the "pipe channel" method because the grass cover on top would provide some detention.
Thank you for your time.
Best,
Serene
Best,
Serene
RE: HydroCAD Tc Line Method for Dry Swales
Thanks again,
Serene
Peter Smart
HydroCAD Software
www.hydrocad.net
Do you mean the Tc line? Would the shallow concentrated flow work as well?
Peter Smart
HydroCAD Software
www.hydrocad.net
If you don't know the conductivity value I suggest you specify a constant velocity instead. Click help on the exfiltration screen for details.
Peter Smart
HydroCAD Software
www.hydrocad.net
