HydroCAD Tc Line Method for Dry Swales
Serene111
I was wondering what method I should use when Tc line is going to a dry swale? There is an underdrain pipe, but I don't think it is proper to select the "pipe channel" method because the grass cover on top would provide some detention.
Thank you for your time.
Best,
Serene
which route would be most conservative approach? I would use the overland flow thru the swale with the grass cover, not the underdrain pipe.
Thank you for the suggestion. I was also trying to model the dry swale using "Pond", but my swale as a 4% longitudinal gradient and I can't find any outlet device that can describe it.
Thanks again,
Serene
Hello Peter,
Do you mean the Tc line? Would the shallow concentrated flow work as well?
Yes, I was referring to a Tc segment for channel flow. For very small depths you could use shallow concentrated flow. Or try both and compare the results.
Peter Smart
HydroCAD Software
Thanks Peter, I'll try both. What about the to model the dry swale using "Pond"? I'm using a pond storage with outlet "exfiltration" and "broad-crested weir", what should be the conductivity in the "exfiltration"? The current model is giving me very small exfiltration at the 100-year storm event I gave a very large conductivity (a random number). I also attached the HydroCAD file here. Please let me know if you have any questions.
 https://files.engineering.com/getfile.aspx?folder=148dc220-6e87-4dc8-92bc-3e12786381d7&file=POST-DEVELOPMENT(test2).hcp
If you have free flow through the swale then you should model it as a reach or a Tc segment of channel flow. A pond node would apply only is you have level pool storage controlled by one or more outlet devices.
If you don't know the conductivity value I suggest you specify a constant velocity instead. Click help on the exfiltration screen for details.
Peter Smart
HydroCAD Software
Got it. Thank you, Peter!
