Contact US
Bonded Contact for Fastener in FEA
If I don't use rbe for predicting the load at fastener... What about using bonded contact?
Imagine in lap shear joint, I use bonded contact at the imprint area where it supposed to be bolt shank?
There was discussion in the team that this is quick and dirty way to check the joint strength but I'm not sure...
RE: Bonded Contact for Fastener in FEA
It's not friction that makes bolts work.
www.sparweb.ca
Oh, right Greg. I was thinking of the contact surfaces of the plates, but you're right about the contact surfaces of the threads. smile
www.sparweb.ca
modelling the joint as a bonded connection will give you the total load reacted, then presumably divide by the number of fasteners (assuming same fastener) for a fastener load … assuming load redistribution within the joint, which may be valid for ultimate loads, but would be invalid for fatigue loads.
Why not model the joint as common nodes. This'll still tell you the bulk load, and easier to implement ?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
