design of inclined tie rods
thread158-267413: deadman anchorage
Hello, I would appreciate some help or advice on designing tie rod anchors and wale beam for sheet pile headwall. Tie rods in this case are not perpendicular to the wall or the wale beam. Tie rods are inclined (45 degrees) in the horizontal direction (i.e. when you look at the plan, not the section view, there is a 45 degree angle between the wall and the tie rods)
Thank you
Thank you
RE: design of inclined tie rods
www.PeirceEngineering.com
