Can hydrocad accurately determine
Can hydrocad accurately determine HGL's?
Thanks!
Thanks!
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Can hydrocad accurately determine
Note that an term HGL generally implies a steady-state analysis, with the entire drainage system at equilibrium, while HydroCAD is a hydrograph routing model, where all the WSE's are continuously changing over time. As such, there is no single HGL for the entire system.
Peter Smart
HydroCAD Software
www.hydrocad.net
Thanks so much for your response. For a typical storm drain network on a road side, would you recommend modeling each catch basin as a detention pond (storage being the actual volume of the concrete catch basin) with a culvert as primary and an overflow weir as secondary for the water that comes out of the grate in larger storm events?
Thanks!
Peter Smart
HydroCAD Software
www.hydrocad.net
