ASCE 24-14 Direction of Wave Approach
We're working on a project in Flood Zone VE and are currently looking at the flood design loads on concrete shear walls below the DFE. We have a number of wall generally orientated perpendicular to each other distributed throughout the structure but with sufficient clearance to allow for the entry and exit of flood waters.
We're trying to understand if the wave direction is generally assumed to be 90 degrees to the shoreline, or if a range of direction (say +/- 30 degs) is considered to check walls which are orientated parallel to the wave direction. Does anyone have any experience with this?
RE: ASCE 24-14 Direction of Wave Approach
That said, if you're just looking at a house, probably best to do a 30 or 45 degree angle if the fetch is there to develop the wave as it probably isn't worth it to chase down more exact numbers.
