Level gauges mounted on a bridle.
Indy
Industrial
GB
I have a question about magnetic level gauges mounted on a bridle. For example if there is a centre to centre distance of 6000mm between the nozzles on the vessel and we want to divide this range( 6000mm/3) between three level gauges then is there a standard distance that the gauges must overlap by?
I don't think there is a requirement of overlapping between gauges.
Have the vendor to propose three equal length gauges with a minimum overlap to cover the 6000mm bridle.
