Thermodynamic process for distillation (concept) - searching for startup partners.
ThermoEngineer
3
The process, described below, can be applied in multiple situations, therefore I share the idea to discuss and also I’m searching for partners to create a startup(s) around this idea.
Any advice is welcome!
The idea of the distillation process is to evaporate fluid from mixture to critical state, which decreases the latent heat of evaporation to zero, and then returns heat energy and pressure energy through a system of heat exchangers and special pressure exchangers to the feeding mixture.
The advantages of the process are:
- Minimum energy usage. The latent heat is zero in the process; heat and pressure energy returns to feeding mixture inside the process. The energy is used only to reduce Entropy and to compensate inefficiency of process, and it means that the energy usage has to be close to the theoretical minimum for a distillation process. It is much more effective than the reverse osmosis process.
- The process uses heat energy - which is the cheapest type of energy.
- The process is very suitable for solar concentrators. Using direct transformation of heat to distillation, it gives an opportunity for solar concentrators to work with highest efficiency, because the process does not waste heat, as other processes do.
Some Clarifications.
Pressure Exchanger (PX) - a device that transfers pressure energy from a high pressure fluid stream to a low pressure fluid stream. There are a lot of types of this device and it is widespread in the desalination industry. Here is the simplified scheme :
Basically, it is a chamber, with a free diaphragm inside and a system of valves and pipes around the chamber. There is no moving parts except diaphragm.
In the diagram the PX feeds the high pressure process, using energy of downstream liquid.
The efficiency of the PX is very close to 100% under the following conditions:
- operates with liquids (no gas)
- pressure drops and pressures are equival upstream and downstream
- flow rates are balanced out upstream and downstream.
Therefore a high pressure pump is needed only for startup and PX inefficiency compensation.
An example of a very similar pressure-exchanger is DWEER, presented in the desalination industry, 4 min video from 2.00: www.youtube.com...
Diaphragm Pressure exchangers were invented in the 70s or earlier, it is an established technology.
Here is the simplified scheme for the continuous process (clickable):
The mixture of fluid 1 and fluid 2 is heating in the evaporator and fluid 1 is evaporated to the critical state. Then fluid 1 and fluid 2 are going to the 3-way heat exchanger, where they are cooled by the feeding mixture. Mass balance for the heat exchanger is perfect just because the upstream fluid mixture = downstream (fluid 1 + fluid 2), the heat exchanger works on counterflows, therefore it is the most favourable state for the heat exchanger efficiency. Then fluid 1 and fluid 2 are going to their pressure exchangers and give their pressure energy to the feeding mixture. The volume and mass balances are close to perfect again.
To compensate the inefficiency of the PXes and for startup processes a high pressure pump is installed.
There are many scenarios for startups and other co-operations, for example:
1. R&D company for the bioethanol process. There is a lot of energy consumed and wasted for water-ethanol distillation. The goal is to make a startup which will modify plants.
2. R&D company for sea water desalination process. (The process has to be more effective than reverse osmosis process)
3. Maybe you are searching for a PhD theme or work in a laboratory with similar processes - you are welcome!
4. R&D company for combining distillation/desalination and solar concentration technologies.
5. A lot of other scenarios beyond my imagination.
I Invite you to discuss the concept and make new startups.
I have read about pressure exchangers used in reverse osmosis. Fascinating technology. However, I have no idea of how you are using this for any benefit in a distillation process. In a supercritical fluid there is no difference between the liquid and vapor phase. So there will be no line in your drawing of an evaporator that designates a phase separation between liquid and vapor. How can distillation work at all in a supercritical fluid, where there is no liquid or vapor phase?
The motive device here could also be a liquid phase recovery turbine? - these are routinely used in amine recirculation service in CO2 absorption plants. No need for switching valves. But agreed, mechanical work transfer eff is somewhat poorer than in a recip / pd pump recovery device. But mechanical reliability would be much better with a recovery turbine.
Agreed, in the critical region, distillation may not work, the less volatile components will also boil up since high temperatures are required at very high pressure.
Latexman said:
That's recruiting.
A company does not exist, therefore no recruiting.
In these sentences you think about 1 fluid in evaporator, but in the scheme we have fluid mix, two different fluids, for example critical water and a brine. The brine definitely has higher boiling point then critical water temperature, therefore a line between 2 fluids exist.
Yes, a turbocharger is the example of that kind of pressure exchangers. But efficiency of turbochargers is not well enough.
Semantics isn't going to win the day here. "Recruitment can also refer to processes involved in choosing individuals for unpaid roles."
in these sentences you think about 1 fluid in evaporator, but in the scheme we have fluid mix, two different fluids,
?? Distillation of alcohol involves a fluid mix, as does oil refining, in a sense.
TTFN (ta ta for now)
Well... I think you may agree that the topic is not about recruitment, but the topic can result in recruitment in the future ( how? What kind of recruitment? - I do not know). Therefore I promise, any talks about recruitment will be outside this forum. Ok?
The distillation of alcohol is azeotropic distillation, therefore it needs a more complex setup. For example, a fractional column can break the azeotrope. If you add a fractional column to the suggested scheme, it will distill an alcohol. Other methods to break azeotrope are also possible.
I am beginning to smell MBA ....
MJCronin
Sr. Process Engineer
