Wow, thanks for all the comments guys. We had a vertical turbine pump in a salt water solution with 416 shaft and it corroded through too. We replaced it with 2205 but it was an approved choice by the OEM. This pump is a different shaft size and I don't know the weight of the impellers. I know the 300's stainless steels were a concern with material strength with the salt water application and figured it would be the same case here. I'd like to go with 2205, but how can I establish confidence in it meeting the application? Are there factors I can run with the list you provided TenPenny? The shaft is running at 200 HP, 1780 rpm, and is 2.18 OD. From the diameter and lower speeds it instinctively seems to be adequate, but I really don't know.
Artisi, I haven't done these calcs. Wouldn't I need to know impeller weights, specific location, use the SG of the fluid, and all of that?
EdStainless, thanks for your comments. Haven't heard of Nitronic 50 before and will look into it. I'm leaning toward 2205, just want to rule out any doubt...
