Contact US
Problem in Etabs while designing a Waffle Slab "FAILED"
Hi everyone, I would like you to help me understand a message that Etabs display while checking the reinforcement on a waffle slab. I designed the waffle slab by the strip method but when I click on display flexural design there is a message on the bottom on the screen that says "FAILED" and I'd like to know the cause for that error. I mean, I checked the maximum reinforcement allowed for the slab (ACI 318-14) and it passes, then checked the punching shear and passed, but ETABS doesn`t tell me why it gives that error. I had to increase the size of the drop panel to eliminate it, however, there is still a "FAILED" message on a middle strip. Concrete f'c = 210kg/cm2, fys= 5000 kg/cm2, The live load is 250 kg/m2, SuperDead 250 kg/m2 and obviously the self-weight is calculated by the software. The clear span are between 4m and 6.5m. The total depth of the waffle slab is 30 cm, the rib width is 10 cm and its height 25 cm, the slab thickness is 5 cm, the spacing of ribs is 50 cm from their axis. I've attached a screenshot, please take a look.
Thanks in advance.
RE: Problem in Etabs while designing a Waffle Slab "FAILED"
tried exporting to safe?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
