"do you want to reiterate analysis and design" Option not available on ETABS 22
X4vier
CO
Was the option "do you want to reiterate analysis and design" removed onrecent versions of ETABS?
Any way to reactivate?
Back when this option was there I didn't use ETABS all that much. But, I do recall seeing it from time to time.
Looking through the current version, I see a "Verify Analysis vs Design Section" on the Design menu. Isn't that essentially the same thing?
I believe it is Josh - in previous versions of ETABS you would finish the designer and it would auto pop-up, reanalyze, redesign, pop up again, until it "converged" or started bouncing between the same design sizes. Verify Analysis and Design is fundamentally the same thing - without the auto popup
Optimal for hovering your finger over the Enter key and closing your eyes for 10 minutes [pc1]
