Mould Material- Injection Moulding
So I just need some tips regarding which is the most appropriate material to use to make the dies to attain a high gloss mirror finish.
RE: Mould Material- Injection Moulding
Commonly is NAK80, if you have higher requirements and budget, SRAVAX, PLOMAX, and S136 also good choices.
thanks
2fprotorypes
specialized in rapid prototype, mold and OEM engineering & manufacturing
I depends greatly on what you are molding.
Is it abrasive (fillers)? Is it corrosive?
These will dictate mold materials.
Often parts that need a high gloss surface are made from harder mold materials.
If one face of the part requires the gloss then this is often an insert so that it can be removed and re-polished as needed.
Many die steels have stupid proprietary names so keeping them straight is a trick.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
