I'm working on a building where I need to calculate the wind load of a building. The walls are comprised of cold formed steel with gyp for shear walls.
I need to calculate the frequency of the building.
My two questions are, how can I determine whether the building is rigid or not, and how can i calculate the frequency of the building?
The applicable code needs to be for NYC if possible.
Any code references would be helpful.
Thank you
Thank you
