Contact US
tapped plate rule of thumb
Hi All,
Is there a standard or a rule of thumb for the thickness of a plate to be welded to a structure that allows for a other framework to be bolted to it.
For instance lets say I have a PFC with and end plate welded to it with thru holes to accept a M14 screw. I want to mount this to an existing structure but want it removable so i want to weld a plate with tapped hole to the the structure. what thickness should this plate be to allow for the threaded connection? 15mm, 20mm?
many thanks
RE: tapped plate rule of thumb
Hi
The rule of thumb I always use is the thread engagement should be at least one bolt diameter but if the material is nothing like the strength of the bolt I would use 1.5 bolt diameter for my thread engagement.
thank you i like that rule of thumb i will keep that in mind for my future applications..
cheers..
There are other options for one sided, removable connections too. Like Hollo-Bolt by Lindapter.
I've always been told to be careful about tapping plates for structural connections.
The rule of thumb we use is the thickness of a nut for that size of fastener. That is, unless the fastener will be used as a pin used in shear rather than as a fastener loaded primarily in tension- then you can get away with much less thread engagement than that, as all the tapped thread is doing is keeping the fastener in place.
True, but as desertfox already pointed out, a nut typically has a yield of 600+ MPa, whereas most structural steels that you'll tap only have a yield of about half of that (same applies for ksi values!).
Meaning you'll roughly need double the thread engagement! Which again does not add up with the fact that more than half of the tensile forces gets (re)distributed in the first 3 - 4 threads.
So, be careful using rules of thumb in soft or thin plates...
Hi Jon
See this link, introductory notes it mentions the rule of thumb I quoted:-
https://roymech.org/Useful_Tables/Screws/Thread_Ca...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
