Doing an Abaqus FEA course and unsure what the proffesor is asking of us?
StructuralCivilFEA
NO
I apply apply a load of -1500N in the vertical direction to the RP_LOAD_Point, and have to do the following:
"Extract from the ODB field output via “Create xy-data” the force/time and
displacement/time curve of the RP_Load_Point. Generate a force/displacement plot out of these curves. What does the plot tell you?" - What does he mean by force curve of the RP_Load_Point?
"Which plies have failed and what kind of failure is predicted?"
We are working with Tsai-Wu and Hashin failure - does anyone know how I can check which plies have failed? I can check the results for each ply, but not sure how to know if any have failed? Does it fail if the value is over 1?
Test setup:
FEA model:
Ply stack plot:
Its not a regular college course, I am just taking to learn more about FEA/Abaqus for my work.
