Return Period for Wind Loading 4
dik
CA
Does anyone have a quick method or adjusting the wind load based on a return period less than that of the normal 30 year, 50 year or 100 year durations?
Thanks in advance,
Dik
I thought it was 1.0 for 100 year and 0.7 for 10 year.
ASCE 7 Commentary for Chapter 26 goes into return period comparisons in their explanation of the change from 50 year in 2005 to the 300, 1700, etc. in 2010.
Thanks, gentlemen...
Dik
A search on the web I found this, Link. I think you can find similar record for the local that you are interested in.
ASCE37-14 has wind speed modification factors for return periods under 5 years.
skeletron:
Thanks very much, I think that was the formula I had seen or one of the same form. I'll check the NBC tonight.
Dik
sbisteel:
Thanks to you also... I'll try to dig up a copy and see what it says.
Dik
sbisteel:
Found a copy... it has the info I can use. Thanks.
skeletron:
I've coded the formula into SMath and will play with it this evening.
Thanks, gentlemen
Dik
Just an FYI @dik: V is in m/s. They define q = 0.00064645 V2 in the previous page. q is in kPa.
Thanks skeletron, that was my next step... I work in both SI and Imperial, but think in Imperial... just too old. I'll post the SMath program when completed... have some real work to do now...
Dik
