Units not transferring in same format from DesignModeler to Mechanical
johcatrac
CA
In WB, I created geometry in mm. Selected mm on the project schematic for the Model and then when double clicked Model, the Mechanical window opened up but showing the model in meter. Any way to change this to mm? Geometry still shows in mm. Thanks
