Chain catenary vertical reaction help
For dead load chain catenary with different y-axis end support positions, it's clear that as more chain is hanging from upper support A) both vertical attachment end reactions cannot be identical, and B) upper support vertical end reaction will be higher than lower support vertical end reaction. How are vertical end support reactions determined - losing my sanity a bit. I think chain horizontal component will be equal across chain length, and a cable would react identical to a chain. S.O.S.
Carcajou
Carcajou
RE: Chain catenary vertical reaction help
I've done numerous catenary cable spans, usually with points loads (traffic signals) along the span, but I never was too concerned about the vertical loads - just the horizontal force and cable tension, which are much larger due to the small sag, and the primary source of stress in the poles supporting the cable span. That said, the incremental analysis that I use to approximate the catenary does calculate the vertical reactions. I'll take a look at my design spreadsheet and see if I can work out how the analysis would change for supports at different elevations.
Clearly there will be no vertical force at the cut end, so the vertical reaction at the support ends will be the weight of the length of the segment that it is supporting.
I have a catenary spreadsheet here:
https://newtonexcelbach.com/2009/06/25/a-catenary-...
It generates the catenary profile from horizontal to support, so for supports at different levels you could set up two catenaries and use Goalseek to find the two spans that give the required total span and sags.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
That's the way to the solution, and essentially how I approached it.
As I see it, it may take some iteration to get the sag for the section you cut to correspond to that of the actual span. Unless someone can suggest a direct solution?
I just realized that for the vertical reactions, the sag is irrelevant. JStephen's approach is the direct solution. You'd need the sag to calculate the horizontal reactions or tension in the chain, though.
The sag effects the length, so it does effect the vertical reactions.
I have updated my spreadsheet (attached) to generate a full catenary with different sags either end, and to adjust the position of the maximum sag and the canary constant using Solver, to generate the curve for any specified sags and cable weight.
Note that:
The left hand length must be less than the total length!
If the solver (right hand button) doesn't find a solution try just adjusting the "A" value only with the left hand button, then the right button to adjust the sags as well.
The solver needs to be enabled.
Let me know if any problems.
Doug Jenkins
You're right, of course. The sag for the section used in the analysis would need to be fairly close to the actual to get the length and total weight close.
Yes
Doug Jenkins
https://www.researchgate.net/publication/239754721...
http://home.earthlink.net/~w6rmk/math/catenary.htm
http://www.dredgingengineering.com/moorings/catena...
TTFN (ta ta for now)
Carcajou
https://newtonexcelbach.com/2020/01/31/asymmetric-...
for download file, more details, and links to solving solver problems.
Doug Jenkins
Link
Amazon Link to current iteration of the book: Link
My Personal Open Source Structural Applications:
https://github.com/buddyd16/Structural-Engineering
Open Source Structural GitHub Group:
https://github.com/open-struct-engineer
In the course of this activity I felt that some boiled down observations could bring catenaries down from higher math to levels that could be easily entered in Excel.
The horizontal force along a catenary cable is equal everywhere, pulling to left on the left of the low point and to the right on the right of it. The vertical force at a support tower is equal to the weight of the cable from it down to the low point. The vertical force at a point on the way down to the low point is equal to the weight of the remaining cable to the low point. The horizontal and vertical vectors at a given point give the angle of the cable at that point and the tension in it. The point tension increases from the low point to a maximum at the tower.
If a tower mount is not clamped then the horizontal tension in any adjacent catenary will be the same. This leads to using a spreadsheet to connect and adjust the sags in a series of catenaries over uneven terrain.
The span and the tower height are not the only givens, the ratio of the tension to the unit cable weight is also a user choice. The heavier the cable the deeper the low point will be pulled, varying the sharpness of the sag. If the cable had zero weight it would be a horizontal line with zero sag. If the total weight per half length equaled the tension it would drop straight down and rise straight back up to the next tower with a span of zero feet. The key point for all the curved shapes in between is that there is only one shape of hyperbolic curve, we are just using the tension/weight ratio and span dimensions to scale where our span fits across that curve.
To calculate a catenary by hand or in Excel, choose:
-a trial horizontal tension N
-a sample cable weight per unit length Q
-the horizontal span distance L
Working in feet & lb or in meters & kg, we find:
A = N/Q the tension to unit weight ratio.
If there is a difference in the elevation of the tower tops, delta He, we find:
M = A*asinh(((delta He/A)/2)/sinh((L/2)/A)) the low point's offset from middle of the span.
Otherwise we use the mid point of the span as the low point.
Either way, using Lp as the distance of a point of interest from the low point we find:
Hp = A(cosh(Lp/A)-1) the height of the point above the low point.
This is also described as the sag if it is figured for an end point.
It is valid for symmetrical spans, for unequal tower top elevations with the low point between them (the OP's question, also called an inclined catenary), for unequal tower top elevations with the low point to one side of them and for any intermediate point.
Sp = A*sinh(Lp/A) is the running length along the cable from the low point.
2x the Sp for the end point of a symmetrical catenary finds the whole span.
Hp is the y where our Lp fits the x of our hyperbolic curve and Sp is the arc length along the curve.
For graphs just generate an incremented table of Lp points as + or - offsets from the low point, copy down the Hp height calculation and graph Lp & Hp as x & y. Start and finish with the Lp for the actual top points to make the top data calcs exact. For the inclined catenary I plotted a second calc moving the lower tower out to where it would be the same height as the taller one. Made this a dotted line and then it was easier to see how the subject span was just part of a longer hyperbolic curve.
The calcs can be done directly in Excel. Goal seek would be needed if you want to go from a desired sag re ground clearance back to the allowable tension or weight. But the one goal seek can solve an entire span or string of spans. If your terrain is extreme you can get locations where the upper tower is actually trying to lift the lower tower (the mid point calc gives an answer outside your span). Then you have to reduce N until the sag droops away from the low tower. Or have a receiving tower design that can resist the uplift, this complicates the cable attachment if it is a cableway. Overall there must have been a lot of trial and error in manual calculation days. I recollect once seeing Plexiglas curve templates being used by transmission line designers to solve fitting to route profiles.
For a point load at the low point, figure out an amount of L about that point that has a cable weight equal to your load. Cut that length out of your graph and slide the two pieces back together. The vertical tension left at the cable ends will equal your load. Could probably just goal seek an Lp offset back up the sag until the point's vertical tension/Sp cable weight matches half your cargo. Oops, actually you have to get back to having the original span. Major distributed point loads such as suspension bridge suspenders would be more complicated. Loads distributed uniformly along the run of the cable are just a heavier cable.
Okay, that's enough recapping of what many of you already know better than I do. Let's go for a ride on the Chilecito cableway, it's in the attached KML below. Set Google Earth's Tools/Options/Touring line settings to Camera tilt 75deg, Camera range 15 meters and Speed 175. Then select the "Top to Bottom" line in Places and click the Play Tour button at the bottom of the Places box.
Sagen.AT has a paper the builder's (Adolf Bleichert & Co) Senior Engineer wrote on the project. Note that the plan views are flipped top to bottom. Google translate will fix the language.
[link "Sagen.At"]http://www.sagen.at/doku/Eisenbahn/Drahtseilbahn_K...[/link]
Wikipedia has articles on the cableway
[link "Mina La Mejicana"]https://es.wikipedia.org/wiki/Mina_La_Mejicana[/link]
[link "Materialseilbahn Chilecito-La Mejicana"]https://de.wikipedia.org/wiki/Materialseilbahn_Chi...[/link]
The site is now a tourist attraction, search Google Image for Chilecito Cable Carril for site pictures.
Bill
Thanks for that Prem Krishna reference. My first reaction was "that's a useful set of formulae", so I set about checking them against a problem for which I knew the answers. However in doing this I discovered possible/probable/definite errors. Have you managed to confirm the formulae in some way?
The formulae I would query are:
(2-6) for T". If I change alpha to beta I get agreement, but that might just be a coincidence.
(2-8) for S". Self evidently, for dimensional reasons alone, the final 1 (that's the number 1) cannot be correct. If I change it to l (the lower case 12th letter of the alphabet) then I get agreement with my test problem, which again might just be a coincidence.
(2.12) for elastic stretch. Self-evidently incorrect because of dimensional inconsistency. If I change it to
(Hl2/X)(1/EA)
I get an answer that is in reasonable agreement with my test problem, but since I have no theoretical justification for this change that might be a fluke as well.
Note that my investigations were entirely arithmetical, based on the one single example. I have done no algebraic / mathematical investigation.
Any comments?
I had not used the formulas myself but made use of another section in the book several years ago.
Made a quick spreadsheet this morning and there is certainly something amiss in the formulas. The formula for S'' does not check out simply doing the case of Z=0 where S' should equal S'' shows an inconsistency in the formula, for a known Z rearranging equation (2-11) seems to provide the correct result for S''. T'' seems to check out when Z=0 will need to do some additional checks on this. Equation 2-10 for X seems to give the wrong sign. I have the first printing of the book from 1978 , ISBN 0-07-035504-5 but I have not had any success locating any errata. A description on the new version in the amazon link I posted seems to indicate that there were some errors corrected from earlier printings.
Edit: Got some contact information for McGraw-Hill and have reached out to them about any errata or any correction to the catenary formulas, if I get a response from them will post back.
Edit2:I'm no longer able to edit my initial post if a forum moderator could edit it to note that there seem to be some errors associated with the formulas and to use with caution that would be appreciated.
Screenshot from my spreadsheet this morning which confirms what you posted. I checked against your spreadsheet as well as IDS's spreadsheet which give consistent results for a sample problem of unity for each of the various inputs.
I now believe that this correction does apply. It is the same formula as one given in the paper "Precise Sags and Tensions in Multiple Span Transmission Lines", by J. Barrien, Electrical Engineering Transactions, 1975, published by The Institution of Engineers, Australia. On its second page this paper gives the formula, introducing it with the traditional and uninformative "It can also be shown that...".
Barrien's formula was what I initially used in my cable spreadsheet. However its accuracy declines as the cable's slackness increases, whilst still remaining adequate for most engineering purposes.
