Ductile Iron, HDPE and PVC Pressure Pipe for Potable Water
What are the recommended compaction percentage for Ductile Iron Pipe, HDPE Pipe and PVC Pipe used for Water Mains?
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Ductile Iron, HDPE and PVC Pressure Pipe for Potable Water
You should first see if the local jurisdiction has requirements that need to be followed, i.e county road & bridge department, state highway department, etc. If the pipeline is going through an open field with no improvements or planned improvements 80% is usually OK. If it is in the shoulder of a road but outside of the roadway prism 90%, if it is under a road, driveway or other area where there will be some type of improvement on top or possibly influenced by the pipeline 95% is usually recommended. The percentages are modified proctor.
