CINT Command won't output result
peter.greaves
4
I'm having some trouble with the attached APDL script (should run for you if you change working directory on line 10). It runs fine, and the crack is clearly working as expected, but when I try to view the results of the crack with PLCINT I get the error " There is no specified CINT data in result file for CrackID = 1. The PLCINT command is ignored.". I've tried all my usual techniques (export a working version from Workbench...) but no luck. Any help will be massively appreciated!
Pete
 https://files.engineering.com/getfile.aspx?folder=60d8e637-edfb-4dc5-8a7a-5d197b4793f5&file=fracture
