Boeing Starliner orbital test failure 2
thebard3
Chemical
May 4, 2018
754
The Boeing Starliner spacecraft launched today will fail to dock with the ISS as intended. The test apparently failed due to a software error which prevented reaching the proper orbit.
Brad Waybright
It's all okay as long as it's okay.
Apparently the glitch caused an "anomaly" in the orbital insertion burn to normalize the orbit with the ISS: Space.com story
I find it pretty cool that the craft has remained stable with no incident other than not completing the mission. From my uninformed position on space travel, that bodes well for the safety factor in these craft at least; considering they are meant primarily for crewed flight.
Andrew H.
The story doesn't say, but if the capsule is stable and functional, will they be able to perform a retro-burn and bring the capsule back to Earth? I assume that that was going to be part of the original test flight.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
That's unclear; the story on NPR said that the craft burned its fuel load because its mission clock was discombobulated, and therefore did not have sufficient fuel to reach the ISS.
TTFN (ta ta for now)
NASA had a press conference and acted like everything's okay except failing to reach the proper orbit, e.g. that if it were manned the crew could have intervened and actually made it to the ISS, that we should expect a normal reentry and landing, etc. That's all within a couple of hours of things going haywire so I'd say it's unlikely that they could really state anything definitive, except that the test failed. No matter the outcome, I'd say this is REALLY good news for SPACEX.
Brad Waybright
It just isn't Boeing's year, is it?
A successful return to Earth remains to be seen. Nothing they said indicated that the MET error could cause a problem with reentry/landing. While it's up there, they might as well do as much in-space testing as they can.
Some of you might like "Failure is not an option" by Gene Kranz one of the flight controllers for the Gemini and Apollo missions.
Per say I don't see this as a failure of mission. And certainly won't effect the people carrying missions. they know what the fault is.
In Gene's book about his time as the boss of the white team in mission control these sorts of things happened multiple times in the developing missions of Gemini and Apollo and from what I have read it continued with the space shuttle as well. Both hardware and human factors.
From what I have read it was the want for a better word gain on the course correction was also at fault and it was constantly adjusting using loads of fuel. ie it was over correcting for small deviations which then needed correcting the other way.
Unfortunately the crew on the ISS won't be getting their fresh food or toilet paper. There was nothing on it that was mission critical and it won't go to waste.
Only technical issue will be the mass of it will be higher than planned for re entry. But the up side of that is that it will be a good test for bringing astronauts down.
They still have enough fuel for a normal retro burn to de orbit. I would like to think that re entry fuel is ring fenced and can only be accessed after multiple interlocks are removed manually either from the ground or by the astronaut.
"They still have enough fuel for a normal retro burn to de orbit. I would like to think that re entry fuel is ring fenced and can only be accessed after multiple interlocks are removed manually either from the ground or by the astronaut."
The good news is you're now aboard the ISS.
The bad news is we hope you like it there!
If I did like it there, then that wouldn't that be GOOD news too?
Brad Waybright
I'll rephrase:
Good news: You're aboard the ISS
Bad news: We hope you like it (cause you're stuck there)
Ars Technica has been following up.
Starliner has two parts: the capsule and the service module. Apparently there was a bug in the software of the service module that could have caused it to fire its engines and ram the capsule after they detached, which Boeing patched while the mission was happening. This one doesn't sound like something the crew could have done anything about, since it would occur after the SM separated from the capsule.
NASA are now conducting a review of Boeing's corporate safety culture, though NASA is still keeping up the ridiculous line about it being premature to decide on needing a second test flight.
"The hurryder I go, the behinder I get" :)
They need to understand that until there's a successful FIRST test flight, there can't be a SECOND one.
Irvine, CA
Siemens PLM:
UG/NX Museum:
That's easy, they already declared that they were successful at testing the hardest parts: NASA Deputy Administrator Jim Morhard said "Systems were tested, but more importantly the teams were tested. The hardest parts of this mission were a tremendous success. The Commercial Crew Program is strong.". They tested their teamwork. And that's the most important thing, not whether the crew is likely to crash and die, but how well they work as a team and the friends they made along the way.
The crew of Apollo 13 came back alive.
They didn't land on the Moon.
Show of hands:
Was Apollo 13 a successful mission?
(I'm personally not sure how to answer. The whole story about Apollo 13 is how "the teams were tested" in ways they never expected.)
I'd call it a failure, because the primary objective was to land on the moon.
The highest priority was to return the crew safely.
I believe Gene Kranz called it a 'successful failure'.
Brad Waybright
