Surge Analysis for piping
URKumar
Marine/Ocean
SG
can anyone advice , what specific software use to do for the piping surge analysis.
RK
A transient one.
There are many different software suites for this, all with some advantages.
You are best to hire an experienced flow assurance engineer / company and use their experience.
If you have a network that will be different to single pipes.
But why are you doing this now if the pipes are already built?
It depends a little on what you mean by "Surge Analysis" ...
Surge Analysis is sometimes called "Waterhammer" or "Steamhammer" analysis in Powerplant and process industries.
There is analysis software available that will develop a forcing function for a particular piping system.
The forcing function results are then typically used to perform a more complete stress analysis of a piping system using an analysis program such as CAESAR-II. The resultant stress levels and loads on pipe supports can be then evaluated.
MJCronin
Sr. Process Engineer
Dear MJCronin,
thank you very much for your advice, and will get contact Singapore agent to provide software and training to my engineers.
Ravi.
Dear Littleinch,
thank you for your advice, however i would like to get trained my engineers to perform this activities in the future projects, we are getting in contact with agents for software snd training.
Ravi.
My opinion. It's more easy to prevent water hammer using special methods like slowly closing valves, using buffer tanks, etc. instead of fighting with it's aftermath like loads, displacements etc.
