Syahar1975
Dear Tank Builder,
Dome roof tank 31 M dia x 14 M Ht designed as per Annex F with 0.75 psi design pressure.
As required by appendix F, the tank must be air tested at 1.25 x 0.75 psi.
The question is : is there any rule of thumb or engineering calculation about safe working distance during the air test.
We are using a pressure gauge and water manometer. How far we are shall or should be from the tank during the air test is in progress.
Thanks.
Syah
Thanks.
Syah
