Question regarding fixity - Slab to shear wall connection
Hi all,
As a useful excersize for my novice self, I have modelled a 3rd floor 300thk RC slab (that has already been built) using FEM, so that I can add loads in certain places to see the behaviour of the slab and supports...
In my FE model (using Autodesk Robot), I have added linear pinned supports (along openings) where ever shear walls are present (please see attached a snip shot of my model and the slab layout) and fixed connections where there are RC columns.
Would this be a reasonable assumption to analyze this slab?
RE: Question regarding fixity - Slab to shear wall connection
For building perimeters, if both slab and shear wall are CIP concrete, I've difficulty to see a pin in the interface. Otherwise maybe fine, depending on wall-shear wall joint details.
It's not a pinned connection.....but then again it's not perfectly fixed either. (If detailed like a fixed connection to each other.)
In general I have found that the moment at that interface is typically not more than what it is in the middle of a bay.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
