VaidehiChennubhotla
A Hyperfoam material model was used for compression test on a 50x50x50 mm block. The compression test data (FS curve) was overlaid on the CAE data. It doesnt correlate in the initial portion as shown in below picture. Hyperfoam material in general has uniaxial test data(compression and tensile), Simple shear test data(Nominal Stress, Nominal Strain). As I understand shear test data predicts when it fails. I think compression test data needs to be fine tuned somehow. What can be done to the Hyperfoam material card, to make it match with test data?
Any help would be greatly appreciated.
Vaidehi
Vaidehi
