Abaqus animation
Abaqus animation
Abaqus animation
I am running a dynamic analysis in Abaqus (implicit) that solves over ~10,000 time increments. I would like to animate the results, but would like to only include every 10 results or so to speed up the animation and reduce the file size. How do I do this? Thank you.
RE: Abaqus animation
You can use Result --> Active Steps/Frames to deactivate unnecessary frames. This will affect animations too. Another way is to use Animation Options --> Time History, switch to Time-based and specify Time increment. Finally you can go to Animate --> Save As and adjust Frame Rate option to speed up the animation.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
